  • 1992 Champion Europremier motorhome maintenance reference list
    My 1992 Champion Europremier motorhome maintenance reference list.
    VIN# 4S7KT9S03NC004534
    Engine: Cummins 8.3 CTA6 - Engine #44645051
    Generator: Onan 7.5 DKDFJ
    1992 Champion Europremier Yearly/Regular Maintenance List:
    Part Description/Part # Quantity Change Interval Cost
    Engine Oil 15W-40 Rotella T w/ Rislone Additive 23.7 qts Yearly $90ish
    Engine Oil Filter Cummins LF 3000 1 Yearly $30
    Engine Fuel Filter Cummins FF 5052 1 Yearly $9
    Engine Fuel Water Separator Cummins FS 1280 1 Yearly $8
    Engine Coolant Filter Cummins WF 2071 1 Yearly, also test DCA $9
    Engine Coolant DCA Level Check Yearly
    Grease Chassis Yearly
    Generator Oil 15W-40 Rotella T, no additive 4 qts Yearly
    Generator Oil Filter Onan 122-0827 1 Yearly $13
    Generator Fuel Filter Onan A026K278 1 Yearly $40
    Transmission Oil Filter Cummins LF 3789 1
    Drinking Water Filter 1
    1992 Champion Europremier Longer Term Maintenance List:
    Engine Air Filter Cummins AF 1813 1 3 years or as needed $40
    Engine Coolant Change 2 years
    Engine Serpentine Belt 3288933 1 5 years or as needed $52
    Engine Belt Tensioner 3978022 or Dayco 89101 1 10 years or as needed $65 on Ebay
    Fuel Shutoff Solenoid Cummins 3935649 1 10 years or as needed $116 on Ebay
    Generator Coolant < 2 Gal.
    Generator Air Filter Onan 140-2842 3 years or as needed
    Fuel Transfer Pump Cummins 4988748 1 10 years or as needed $65
    Front Shock Absorbers Bilstein 24-186407 2 As needed $200
    Rear Shock Absorbers Bilstein 24-015943 2 As needed $200
    Engine Radiator Cap Stant 10230 (16Lb) 1 10 years or as needed $10
    Tires Yokohama 6 7-10 years or as needed $2600
    Transmission Fluid Coastal Dex Merc ATF 19 qts? $70
    Air Dryer Filter Bendix 1 3 years or as needed $60
    Notes:
    • DCA (I've seen SCA referred to in some more modern documentation, not sure if there's a difference) level in engine coolant is very important for this and many other Diesel engines to prevent pitting and ultimate destruction of the piston sleeves.
    • Fuel filters may go longer depending on conditions and fuel quality.
    • Drain Fuel Water Separator monthly when not in storage.
    • Drain air tanks every 3 months when not in storage.
    • Belt tensioner, fuel solenoid and fuel transfer pump are known "strand you in the middle of nowhere" items so I prefer to replace them before they get into the stage of their life where failure is imminent.
    • My change intervals are mostly based on time and not mileage since myself and most other motorhome owners won't typically drive enough to hit mileage limits before hitting time limits.
